Has anyone had any luck establishing a listener in Celigo for Asana webhooks ? Asana uses a process to verify the webhook by returning a secret value in X-Hook-Secret (https://developers.asana.com/docs/webhooks) and I don't know enough on how I can potentially handle this and return it to send the handshake back.
Hello Glenn, I haven't tried this but I'm checking here internally.
Unless you have time critical dependant tasks in the destination for this flow, I think using with our Asana connector is better. We support all major APIs/resources in our Asana connector.
You could have a batch flow running every 15 minutes fetching delta.
Hi Jagan,
Thanks for that. The normal API's work for most use cases, I'm just trying to build out for deletion events. There is an event API that I might be able to build a flow around instead, was just putting it out there in case I missed something obvious.
Glenn
