Design Advice (XML) - api/flow?
First off, I'm very new to the platform, and I'm not entirely sure of it's capabilities, so I need expert advice :).
At a very high level, I need to accept an XML request via an endpoint, query an ERP for data, and respond to that request in XML. I have schemas and sample request/responses.
I guess I'm just wondering what something like this would entail, or if it's even possible.
Any advice, suggestions, or resources is much appreciated.
Thank you in advance.
It sounds like you need an API since you need to synchronously respond to the system asking for data. Our API builder doesn't support XML, but you can use JavaScript APIs to support this. Here is a sample JavaScript API I made to showcase:
import { exports as celigoExports } from 'integrator-api'
// 'exports' is reserved at module scope, so alias it.
// Other namespaces: import { imports, connections } from 'integrator-api'
function handleRequest (options) {
  var rawXml = options.rawBody || ''
  var orderId = extractTag(rawXml, 'OrderId')
  if (!orderId) {
    return {
      statusCode: 400,
      headers: { 'Content-Type': 'application/xml' },
      body: buildFault('ValidationError', 'Missing required <OrderId> element.')
  var record = dummyLookup(orderId)
  if (!record) {
    return {
      statusCode: 404,
      body: buildFault('NotFound', 'No order found for OrderId ' + orderId + '.')
  var responseXml =
    '<?xml version="1.0" encoding="UTF-8"?>' +
    '<OrderDetails>' +
      '<OrderId>' + escapeXml(record.orderId) + '</OrderId>' +
      '<Customer>' + escapeXml(record.customer) + '</Customer>' +
      '<Status>' + escapeXml(record.status) + '</Status>' +
      '<Total currency="' + escapeXml(record.currency) + '">' + escapeXml(record.total) + '</Total>' +
      '<ShipDate>' + escapeXml(record.shipDate) + '</ShipDate>' +
    '</OrderDetails>'
  return {
    statusCode: 200,
    body: responseXml
function dummyLookup (orderId) {
  // OPTION A — Saved export (resource lives in the account, referenced by _id)
  // var result = celigoExports.run({ _id: '<savedExportId>' })
  // OPTION B — Virtual export (defined inline, exists only at runtime)
  // Example below is an HTTP/REST GET against an ERP. Shape varies by
  // adaptorType: HTTPExport, RESTExport, NetSuiteExport, RDBMSExport, etc.
  // var virtualExport = {
  //   adaptorType: 'HTTPExport',
  //   _connectionId: '<connectionId>',
  //   http: {
  //     relativeURI: '/orders/' + orderId,
  //     method: 'GET',
  //     response: { resourcePath: 'data' }
  // var result = celigoExports.runVirtual({ export: virtualExport })
  // For paginated results, use celigoExports.runVirtualWithPaging({ export, pagedExportState }).
  // Both options return roughly: { data: [...], errors: [...] }
  // var row = result && result.data && result.data[0]
  // if (!row) return null
  // return {
  //   orderId:  row.OrderID,
  //   customer: row.CustomerName,
  //   status:   row.OrderStatus,
  //   total:    row.OrderTotal,
  //   currency: row.CurrencyCode,
  //   shipDate: row.ShipDate
  var fixtures = {
    '123': { orderId: '123', customer: 'Acme Corp',     status: 'Shipped',     total: '249.99',  currency: 'USD', shipDate: '2026-04-28' },
    '456': { orderId: '456', customer: 'Globex Inc',    status: 'Processing',  total: '1875.00', currency: 'USD', shipDate: '' },
    '789': { orderId: '789', customer: 'Initech LLC',   status: 'Backordered', total: '42.50',   currency: 'USD', shipDate: '' }
  return fixtures[orderId] || null
function extractTag (xml, tagName) {
  var re = new RegExp('<' + tagName + '\\b[^>]*>([\\s\\S]*?)</' + tagName + '>', 'i')
  var m = xml.match(re)
  return m ? m[1].trim() : null
function escapeXml (s) {
  return String(s)
    .replace(/&/g, '&amp;')
    .replace(/</g, '&lt;')
    .replace(/>/g, '&gt;')
    .replace(/"/g, '&quot;')
    .replace(/'/g, '&apos;')
function buildFault (code, message) {
  return '<?xml version="1.0" encoding="UTF-8"?>' +
    '<Fault>' +
      '<Code>' + escapeXml(code) + '</Code>' +
      '<Message>' + escapeXml(message) + '</Message>' +
    '</Fault>'
Sample cURLs:
# Test the 404 path
curl -X POST "https://api.integrator.io/v1/apis/<your-api-id>/request" \
  -H "Authorization: Bearer <your-api-token>" \
  -H "Content-Type: application/xml" \
  --data '<Order><OrderId>999</OrderId></Order>'
# Test the 400 path (no OrderId)
  --data '<Order><Customer>Acme</Customer></Order>'
# Send from a file instead of inline
  --data-binary @order.xml
# See response headers (verify Content-Type: application/xml comes back)
curl -i -X POST "https://api.integrator.io/v1/apis/<your-api-id>/request" \
  --data '<Order><OrderId>123</OrderId></Order>'
Related articles:
WOW :star_struck:
This is a fantastic starting point, thank you so much.
I really appreciate your effort on this.
