@jackharris if you need to use the state api, here is an example of how I would use it via a preMap script. Notice that the output is the same data coming in, but it adds a new cache object. Within that, it has the stored control numbers for you to reference in your file definitions. Each time this runs, it will grab the stored control numbers and then increment the stored control values by 1. It's a bit complex, but should do the trick for you.
import ioapi from 'integrator-api';
//name your state key here
var stateKey = 'edi840Increments';
function preMap (options) {
let stateCache;
//get current cache key value, but if cache is not already made then create new cache
try {
stateCache = processCacheRequest(stateKey, options._integrationId, 'GET');
} catch (e) {
if (e.message.indexOf("Unable to locate cache with key") > -1) {
stateCache = {
interchangeControlNumber: '000000001',
groupControlNumber: '000000001'
processCacheRequest(stateKey, options._integrationId, 'PUT', stateCache);
} else {
throw new Error(e.message);
//now increment the control numbers by 1
stateCache = {
interchangeControlNumber: lpadIncrement(stateCache.interchangeControlNumber, "0", 9, 1),
groupControlNumber: lpadIncrement(stateCache.groupControlNumber, "0", 9, 1)
processCacheRequest(stateKey, options._integrationId, 'PUT', stateCache, true);
//console.log(JSON.stringify(processCacheRequest(stateKey, options._integrationId, 'GET')));
return options.data.map((d) => {
d.cache = stateCache;
return {
data: d
function processCacheRequest (cacheKey, integrationId, method, cacheUpdates, clearCacheFirst) {
if(!cacheKey) throw new Error('Missing cacheKey parameter');
if(!integrationId) throw new Error('Missing integrationId parameter');
var cache = new StateCache({key: cacheKey, integrationId});
if (method === 'GET') {
return getCache(cache);
} else if (method === 'PUT') {
if (!clearCacheFirst) {
clearCacheFirst = false;
return putCache(cache, cacheUpdates, clearCacheFirst);
} else {
throw new Error('method !== PUT or GET');
function getCache(cache){
return cache.read();
function putCache(cache, cacheUpdates, clearCacheFirst){
if (!cacheUpdates) throw new Error('!cacheUpdates');
if (clearCacheFirst) {
cache.clear();
return cache.update({cacheUpdates: cacheUpdates});
class CacheMissingError extends Error {}
class StateCache {
constructor({key, integrationId}){
this.key = key;
this.integrationId = integrationId;
update({cacheUpdates}){
const startingVal = this.read({ignoreMissing: true});
const updatedCacheValue = {...startingVal, ...cacheUpdates};
const updateCacheValueRes = ioapi.state.putForResource({
resourceType: 'integrations',
_id: this.integrationId,
key: this.key,
value: updatedCacheValue
//console.debug(JSON.stringify(updateCacheValueRes));
return updatedCacheValue;
read({ignoreMissing} = {}){
let getCacheValueRes;
try {
getCacheValueRes = ioapi.state.getForResource({
key: this.key
} catch(e) {
if(ignoreMissing)
getCacheValueRes = {};
else
throw new CacheMissingError(`Unable to locate cache with key: ${this.key}`);
//console.debug('getCacheValueRes', JSON.stringify(getCacheValueRes));
return getCacheValueRes;
clear(){
const deleteCacheValueRes = ioapi.state.deleteForResource({
key: this.key
//console.debug(JSON.stringify(deleteCacheValueRes));
function lpadIncrement (string, padString, length, increment) {
var str = (Number(string) + increment).toString();
while (str.length < length)
str = padString + str;
return str;
