Creating Flow Groups Within a Flow Group
I dont think there is a way to do this, but wanted to ask to be sure. Is there a way to create a flow group within a flow group? For example, if I have an Integration tile called "Engineering" and wanted to create a flow group within that integration called "Datalake Flows", and then put all of my datalake flows within that flow group into other flow groups (i.e. HubSpot>AWS S3, Salesforce>AWS S3, etc)?
Essentially like a Parent folder (Integration) with the ability to add as many child folders (flow groups) as needed to organize flows.
@daveguderian you're correct, there currently isn't a way to create a flow group within a flow group in Celigo. We do have this idea in the backlog, but have not prioritized it at this time. I'll add your vote to it! Thanks for the feedback.
Thanks for confirming Tyler. Happy to hear that its currently in the backlog!
