Could not compile handle bar (define lookup criteria)
Hi,
I'm struggling with the below.
Trying to import netsuite employees with this lookup criteria:
The export app stores Employee ID in the Employee_ID field. NetSuite stores it in the Hibob ID field.
Export applicaton:
Import app:
Getting following error:
Could not compile handle bar "{{{Report_Entry[*].Employee_ID}}}" because "Parse error on line 1: {{{Report_Entry[*].Empl ---^ Expecting 'ID', 'STRING', 'NUMBER', 'BOOLEAN', 'UNDEFINED', 'NULL', 'DATA', got 'INVALID'" .Please correct and retry
I also tried "is" instead of "equal to" in the handlebard, but same result.
Thank you!
It seems you have multiple report_entry json objects. Are they all filled in correctly?
And maybe try to use the one to many option:
Then in the search filter, you can just use Employee_ID then it will execute the import per object.
One to many is used in cases where you have a single record which internally needs to create multiple records.
Thanks @nuriensing!
I do indeed have multiple report_entry json objects:
I tried what you proposed:
Could you please point me to some documentation on how to handle mapping for multipe report_entry jsons? I managed to import records into NetSuite but the mapping is apparently wrong becasue fields are empty (name, email, etc.):
My output is empty:
If you use one to many, then it will do an import based on the N number of child objects.
This means in the left side of your mapping you can use Name instead of Report_Entry[*].Name and this is the case for all the nodes which fall under Report_Entry. If you want to map properties above the child node then you can use _PARENT.propertyname.
Hope this helps.
thank you so much @nuriensing
