Connecting to an On-Premise Active Directory
Hi Everyone,
We are wanting to put together a flow that will create users in an On-premise Active Directory, based on details that have been entered into our HCM platform as part of the employee on-boarding process.
I haven't really been able to find any documentation around creating connections using the on-premise agent to connect to AD, only a connection to connect to Azure Active Directory. We do have an Azure AD, however it's source of truth is the on prem AD.
We currently have an on-premise agent setup, and connecting to other on-prem applications.
Thanks for your help.
@greghunt, thanks for your post! I've moved the post to the "integrator.io – Troubleshoot custom flows" forum for visibility.
Hi @anithaabraham, I have exactly the same issue reported by @greghunt
Wondering if CELIGO has provided him with an answer to sort the issue out.
Hi @greghunt and @serviceceligo,
Thanks for your post. Currently we don't have any connector for On-Prem Active Directory. However, we are actively working on it and should have something to share soon
