Conflict when pulling snapshot of integration to a clone
Hi there,
So we have an integration that we clone to create dozen of integrations (each using different connections). Lately, I've been modifying this "template" integration to add additional flows.
Now that I'm confident that my changes can now be pulled into the cloned integrations, I snapshotted the "template" integration and I'm now trying to pull that image onto my cloned integration. I'm facing a frustrating conflict regarding the /debugUntil field
Frustrating because I cannot simply "empty" this field before snapshoting / pulling.
How can I help you help me fix this situation ?
@philippefoisy
I want to make sure I understand what happened: when you try to merge the changes from the "template" integration into the clone, you run into conflict due to "/debugUntil" field. Is the issue you cannot resolve the conflict manually?
I suggest that you log a support ticket so we can investigate this further and we'll help to set the value for you. We'll look into fixing this so that we don't take into account /debugUntil value as a conflict. Thanks
Hi @viliandyleonardo,
That's exactly it. I didnt create a ticket as I wasnt sure I wasn't my own problem :)
Regards
I submitted a ticket, see ID122952
Thx in advance
Good afternoon everyone,
After discussing with the Celigo Team, I was given a temporary workaround while the Celigo team works on omitting the /debugUntil field in the merge process.
Before snapshotting a "template" integration, you have to "patch" all the exports / imports to remove their respective /debugUntil fields. To do that, a REST API request is required :
PATCH https://api.integrator.io/v1/exports/
Authorization: Bearer
Body:
"op": "remove",
"path": "/debugUntil"
Doing this cleanup, doing a snapshot, and then pulling the snapshot on the cloned integration resulted in no merge conflicts.
@philippefoisy
Thank you for sharing. We are targeting to have the fix released as part of r3 release time line - ETA mid September.
Vili
