Changing Document in B2B Manager Dashboard
I am receiving a 940 from a trading partner.
The way that it’s mapped is the W05*03 is the Purchase Order Number
This value shows up in the Doc No. field of the EDI Dashboard.
In our WMS, though, we’re using the W05*02 as our transaction Identifier. I tried using the Override trace key template and the Data URI template to override it, but neither seems to be working.
Information on the Export/Listener
  • It’s an AS2 connection, and I’m using an FTP connector for testing
  • Once the data comes through, I’m using a transform to update the format to go into the WMS through an HTTP API Universal Connector
    • This is the data after the transform
  • It’s a single file with multiple 940s contained
  • Here’s what the data looks like after the transform
How do I change the Document Number in the EDI Dashboard to be the W05*02 instead of the W05*03?
@jackharris Can you please try now? The dashboard should be able to capture W05*02 for the 940s.
It looks like it’s working now, but I don’t know what was changed. I’m also waiting to see more 940s come through to confirm.
