I found Plans to add One to Many support to Branching? from a few years ago which suggests a solution that I cannot seem to make work for my purposes, so I am going to revive this idea.
I worked with the team during Office Hours yesterday and came up with the first part of a solution for turning error messages into a data point:
function preSavePage(options) {
var data = Array.isArray(options.data) ? options.data.slice() :
var errors = Array.isArray(options.errors) ? options.errors :
var remainingErrors =
// Mark all successful data records with exists: true
for (var j = 0; j < data.length; j++) {
if (data[j] && typeof data[j] === 'object') {
data[j].exists = 1
for (var i = 0; i < errors.length; i++) {
var err = errors[i] || {}
var errStr = JSON.stringify(err)
// Check if "record not available" appears anywhere in the error
if (errStr.indexOf('record not available') !== -1) {
var record = {}
// If retryData exists for this error, carry forward the original record
if (
err.retryDataKey &&
options.retryData &&
options.retryData[err.retryDataKey] &&
options.retryData[err.retryDataKey].data !== undefined
var original = options.retryData[err.retryDataKey].data
if (original && typeof original === 'object') {
record = Array.isArray(original) ? original.slice() : Object.assign({}, original)
record.exists = false
data.push(record)
continue
remainingErrors.push(err)
return {
data: data,
errors: remainingErrors,
abort: false,
newErrorsAndRetryData:
The above creates an “exists” data point and then I use results mapping to pull data.0.exists into a field called cre. I would then like to use cre to Branch
Branch 1: Continue on cre=1
Branch 2: Log to Error Log on anything else
But cre is added on a Path to Many step. My path:
- Find if records need updated per endpoint (up to 5 rows)
- Branch (1 row per branch based on existing in Step 1)
- Pull json for all records that need updated (in this case 25 sub-records) [Path to many]
- Check if Master record exists in destination for each sub-record [Path to many] (using above JS) and assign cre to each record
- Branch ← this is the PROBLEM [No Path to many]
- Master Record Exists
- Check if sub-record exists in destination [Path to many] (using above JS) and assign cre2 to each sub-record
- Use cre2 to determine Composite path (POST/PATCH) [Path to many]
- Log the update
- Master Record Does Not Exist
- Log to the error log
I can use the logic in a composite (as shown in 5.1.2 above) assuming both of my solutions should follow the same downstream path).
I know, as a workaround, I can create a new flow step that breaks my data into multiple records (rather than many:1). For this project alone, I would be required to add about a dozen new flows. While that might not seem like an issue to Celigo, I don’t want to run out of flows in my plan or be forced to upgrade because the best I can do is a workaround.
