AS2 Decryption failed
Hi Team.
I am currently setting up an AS2 communication , and I am encountering an issue while transmitting EDI messages through the system. Here is a detailed explanation of the issue:
When I send an EDI message without encryption, and use base64 encoding, the message is successfully received and processed.
However, when I use encryption (with matching certificates and the same encryption method on both ends), I consistently receive the following error message:
"There is an error in receiving the EDI message. Error message: Decryption failed."
I have verified that the encryption algorithm, certificates, and private/public key pairs all match. Additionally, I have confirmed that both the public certificate for encryption and the private key for decryption are configured correctly on both sides.
Interestingly, when I manually decrypt the encrypted message using the same private key on my local machine, the decryption is successful, and I am able to read the message.
I would appreciate any assistance in resolving this issue as it seems to be specific to the AS2 communication process, and the decryption error only occurs when the message is encrypted.
Here is a summary of the steps I've followed:
Encrypted the EDI file using the public certificate (using the correct encryption algorithm).
Sent the encrypted file with the correct headers and base64 encoding in the curl request.
Received the error: "Decryption failed".
Please let me know if you need any additional information or if there are specific configurations I may have missed.
Thanks
You mention encrypting the EDI file and sending the result with curl.
AFAIK in AS2 the whole mime message should be encrypted,( including headers and signature), not just the edi message itself.
Here's a nice writeup on stackoverflow how to do it:
https://stackoverflow.com/questions/42390232/edi-as2-http-trace
Thanks, Bas.
I was able to successfully send the file by embedding the MIME headers directly into the EDI payload, then encrypting and base64-encoding the result. Here's the process I followed:
1. Embed MIME headers within the EDI file (encapsulating them within the transaction itself):
  Content-Type: application/edi-x12
  Content-Transfer-Encoding: 7bit
  Content-Disposition: attachment; filename="edi940.edi"
ISA*00*          *00*...........
2.Encrypt the file using an algorithm such as 3DES,AES128...:
  openssl smime -encrypt -binary -des3 -in new.edi -outform DER -out 3des.p7m pub.cer
3. Convert the encrypted file to base64:
  base64 3des.p7m > 3des.p7m.b64
4. Post the base64-encoded file using a `curl` command:
  curl -X POST "https://api.integrator.io/v1/as2" \
    -H "AS2-From: testt" \
    -H "AS2-To: test" \
    -H "Content-Type: application/pkcs7-mime; smime-type=enveloped-data" \
    -H "Content-Transfer-Encoding: base64" \
    -H "Message-ID: <msg-id@a-test.com>" \
    --data-binary @3des.p7m.b64
