I am encountering an issue with myAPI script where I am receiving the following response:
"statusCode": 400,
"headers": {},
"body": "{\"message\":\"API call is not allowed(unsupported container).\"}"
I am unsure about the meaning of the error message. Can anyone please explain it to me?
Here is the relevant code snippets. It is a POST or GET to a graphQL api:
main function snippet
let productObj = exportObjDefinition_test(options,connection_id);
try {
invokeExportResponse = exports.runVirtual({export:productObj});
console.log(JSON.stringify(invokeExportResponse));
response.statusCode = 200;
} catch(e) {
console.log("be")
invokeExportResponse = JSON.stringify(e);
response.statusCode = 400;
function exportObjDefinition_test(options,connectionId) {
let orderId = options.orderId;
let orderNumber = options.orderNumber;
return {
"_connectionId": "${connectionId}",
"http": {
//"method": "POST",
"method": "GET",
"body": `{"query":"query {\n languageList {\n totalCount\n edges {\n node\n }\n }\n}","variables":{}}`,
"formType": "http",
"response": {
"resourcePath": "data"
"rawData": "removed",
"adaptorType": "HTTPExport"
I also tried using formType: graph_ql, which also did not work. And also used an existing flowstep export and getting the export definition object > body via the Celigo REST (Postman), which gave me the same error.
Can anyone help me solve this issue? Thank you.
