Did you know you can enable Celigo AI for the Advanced Field Editor (AFE)?
To enable this setting, browse to your User Profile. Near the bottom, check the “AI for advanced field editors” box and save the new setting.
When you configure flow steps, settings with an AFE option will now have a Celigo AI prompt. A great use case is to help you write handlebar expressions!
