After flow branching update, how do we re-order bubbles?
After our recent update I can't figure out how to re-order bubbles. Used to be I could click on a bubble and drag it before or after another bubble and things would re-order, but now nothing happens. I've read the flow branching docs and am not seeing anything about re-ordering bubbles.
What's the new way to accomplish bubble re-orders?
Hi @steveklett,
Thanks so much for letting us know this is an important feature for you. When we implemented flow branching, we had to remove this functionality temporarily. We've heard from several other customers how important this is and are working to get this added back soon. It's a more difficult process to reintroduce with flows with branching - do you use that feature? Would it be helpful if, as an interim fix, we added it back only for flows with no branching?
Hi @courtneyjordan I rely on this quite a bit. Because there isn't a way to log or "see" the data as it runs through the flow I'll drop a lookup bubble with known bad configuration to force an error, I then look at the retry data to see what was in the flow run. Don't get me wrong, I wish I didn't have to resort to this ugly hack. Re-ordering is needed to move this "log bubble" to where I need it in the flow.
Yes, adding it back for branchless flows would be good, I'll take anything at this point.
Also a request for the future: Can you tell us when a release is going to remove functionality? I read the release notes and would have contacted Celigo right away to object. It's also nice to know when a behavior is expected instead of wondering if it's you, your browser, logging out, clearing cache, etc.
Yes, I will make sure that this is part of the process going forward. Thank you so much for helping us understand your use cases for how you're using this feature. I'll try to post back as soon as I have some more info here.
Thanks Courtney, I just re-read my post and laughed at
Who do I think I am?! .. what I mean was I would have expressed my concern :)
Hi @steveklett,
Ha! I think you are right in both instances. We are improving our release process as of you and other customers bringing this miss to our attention. We really appreciate everything you do to improve our user experience and release process, and will definitely improve this notification process to you and others as a result.
