A multilingual Slack help desk on Celigo, built from Claude instead of the UI
We replaced our help desk's native Slack connector with an intake bot built on Celigo. Employees DM the bot in English, Portuguese, Ukrainian or Russian. A Celigo AI agent drafts the ticket as a card, the employee confirms it, and the ticket opens in the right FreshService workspace for their request type and region (US, Brazil or Ukraine). Agent replies and status changes come back into the same Slack thread, and the Home tab lists everything they've opened. It went live on November 11, and the first release of fixes shipped on November 24.
The part I'd most like to share is how it's built. Almost none of it was clicked together in the Celigo UI. I build in Claude through Celigo's MCP server and CLI, with Celigo's own skills loaded for the platform rules. Claude reads the flows, writes and unit-tests the scripts before they touch an environment, wires the hooks and reads every change back, and I review each change before it goes in. Changes move Sandbox to UAT to Production through ILM pulls, with every environment-specific setting on the pull ignore list. A small Cloud Run relay sits in front of Celigo because Slack wants an answer within three seconds: it acknowledges in under one and forwards to the Celigo listeners. What I'd still like is Ora's platform knowledge available inside that workflow, not only in the UI.
Three headaches it saved us from, in case they save you one:
  1. Slack silently drops message metadata over 4,000 bytes. Cyrillic takes two bytes per character, so a long Ukrainian request produced a card that looked fine and a button click with nothing behind it. Now the card's metadata stays small, the text is rebuilt from the thread at submit, and the card fails loudly if Slack drops anything.
  2. Celigo processes listener events in parallel, which is great until an agent sends three replies in five seconds and three runs each post what they see. The relay now posts each reply exactly once, under a per-thread lock.
  3. Routing that must be right every time doesn't rest on the model alone. For a few request types that carry sensitive data, a deterministic match on the requester's own words decides the route, and the AI is a second signal. Any disagreement routes toward the more restricted team. Same principle as Celigo's least agency post.
Kurt Foster, VEC
