UI Bug: Right-Side Columns Disappear When Dragging a Column
When dragging a column in the Integration Flows table, the right-side columns such as Disable/Enable disappear from view.
It looks like a UI bug, because after moving or dragging a column, the table layout does not preserve the visibility of the action columns on the right side. These columns should remain accessible, or the table should adjust properly without hiding them. Also when dragging the column back, the enable/disable does not show.
If you scroll to the right aren't they there?
Ah yes then its there, but to move everything back is a bit difficult, I cant move it on screen anymore and have to refresh.
We'll take the feedback, but it's not dissimilar to Jira lists or tables in Google Docs, or most systems that allow table column resizing. Other systems also often keep the resized width as your preference, which we could do, but we opted not to since users change screens and then stuck widths wouldn't travel well.
