Does #filter handlebar work in import mappings?
Hi Everyone,
Does the filter handlebar work in import mappings? I tried to play around with it in the Playground tool and seems to work.
When I try to use it in the import mappings, the following error shows up.
I appreciate any inputs.
Thank you
Hi @Marco_Esteban Thanks for raising this. The team is checking this.
Are you trying to add this to an existing NetSuite import or did you make a new NetSuite import? I'm wondering what suitescript version the import is using.
hi guys, do we have an update on this issue? I’m running into the same issue. Filter works in playground, mapper 1.0, mapper 2.0, but seems it doesn’t work on netsuite adapter even when using ss2. It seems the ns adapter mapper has not been updated to use this new filter function.
