We have been receiving a high quantity of 403 Invalid Response errors from NetSuite integrations starting around noon PT. Seems to be intermittent. Anyone else experiencing the same?
Status: Resolved on October 28 at about 3:15 PM PT — Celigo-side, North America only.
Celigo moved its NetSuite traffic to a different address, which stopped the errors; NetSuite has an open case. Nothing in your account changed, and you don't need to re-authorize anything. Retry the failed records in Error Management (Manage all > Retry All, upstream flows first) — the refused requests never reached NetSuite, so retries do not create duplicates. See Resolve NetSuite invalid response HTTP 403 errors across all NetSuite connections for full instructions.
Starting October 28 at 11:31 AM PT, NetSuite requests from part of Celigo's North America infrastructure are being refused with HTTP 403 Forbidden and an empty response. In integrator.io this appears as invalid_response errors on NetSuite exports, lookups and imports, and as NetSuite connections flipping offline. EU, Canada and Australia are not affected. This is not caused by anything in your account — re-authorizing or switching NetSuite connections will not help. Celigo engineering is moving traffic off the affected servers now. Failed records are retained and can be retried once errors stop (they were not written to NetSuite, so retrying does not create duplicates). We will update here.
Update: Maybe not - connections are still going offline. Flows are failing again with the same invalid response error
The issue seems to be clearing up.
Dear Celigo,
You handled this great and I really appreciate it! The communication and the transparency was absolutely the right call and helped keep things cool. Keep it up!
This issue has returned as of 9:15 AM PT on 11/4/26
Hello Everyone, I started receiving the same error message today.
this seems to be resolved for me now. However, I'd like an update regarding what NetSuite responded to the case Celigo raised to understand how this keeps happening.
Hi @Brandon_Scapa, thanks for flagging this.
Today’s errors, starting around 9:15 AM PT, followed the same pattern as October 28. Our team moved the affected traffic and errors cleared shortly after. As before, nothing in your account changed and there’s no need to re-authorize. The affected requests never reached NetSuite, so retrying failed records in Error Management won’t create duplicates. Full steps are in this article.
On your question about why this has recurred: we’re working directly with NetSuite on a longer-term fix, and they’ve been responsive. In the meantime, we’ve improved how quickly we detect and respond to this, which helped keep today’s disruption shorter.
We’ll share an update here as we make progress.
Thanks,
Matt Graney
Chief Product Officer, Celigo
It's happening again, can't make any requests to NetSuite.
This is happening again now, is there any possibility for a workaround when that happens?
Do we know if this was caused by a NetSuite or a Celigo change? If this was a Celigo change, it needs to be rolled back in my opinion. It is clearly defective.
@steveklett @Saif_Bissar @Brandon_Scapa
As before, there is no end-user workaround, @Saif_Bissar .
Some of our IP addresses are being blocked by NetSuite due to what we can only assume are false alarms in their API security layer. As this happens, our team responds quickly by moving workloads to other servers, but there is a lag which users experience as a failure to make requests to NetSuite.
We have escalated this with NetSuite to get to the bottom of the problem. You may help our collective cause by raising your own support tickets with NetSuite too to help stress the importance of getting this resolved.
Regards,
Matt
Hi @mattgraney,
I've had one client share an RCA from NetSuite related to this and that RCA is claiming that Celigo was hammering NetSuite with authentication requests using stale credentials (whatever -that- means??) which is what triggered the IP block. I think if that was indeed the case you or @kathyanaqueeman would have probably mentioned it, but I thought I'd let you (and this thread) know that the claim is out there.
If it's not accurate, anyone submitting a NetSuite case should proactively address and refute this or we all know what NS support will do with the case.
Here's an excerpt:
Root Cause Analysis (RCA):
Based on our internal investigation, we identified that the affected IP address had been blocked on the NetSuite side.
During a previous occurrence of this issue, our investigation confirmed that Celigo had introduced changes on their end that resulted in repeated authentication attempts using stale credentials. These attempts generated multiple failed logins, which subsequently triggered the IP blocking mechanism.
Hi @steveklett ,
That was indeed the initial response but was inaccurate. However, we made progress overnight in aligning NetSuite to our understanding of the issue. As a result, our IP address ranges have been whitelisted and so we should not see a recurrence of this problem.
Thank you all for your patience as we worked this out with NetSuite.
Regards,
Matt
